amenic
Sep 17, 2020Apprentice
Intermittent DNS lookup failures on RBR850
Intermittent DNS lookup failures RBR850 I've been using the Orbi RBR850 for several months now and I'm constantly having issues with DNS that I've NEVER experienced with any other router I've ever u...
musicbravo
Dec 04, 2020Guide
Yes. Ideally, if I get ORBI behaving in router mode, I will disable all but the 2.4ghz radio on the r7000 and put it back in ap mode leaving rbr850 to make router mode. Sadly I have one device that won't connect to ax networks so have to keep the r7000 2.4ghz alive at 25% so it can still communicate with that one device
Dec 04, 2020Guru - Experienced User
You can do this, just keep one router on channel 1 and the other on channel 11.
