1topgazza
Dec 09, 2022Aspirant
Intermittent loss of internet connection RBR 350
I have the RBR350 with two satilites. I was getting the odd loss of internet on WiFi message. Rebooting the modem/router, a Sky Broadband Hub, worked. This was happening every couple of weeks. Now it’...
1topgazza
Thanks for replying
Tonight no one was actively trying to connect to a website. I was watching Netflix over Ethernet and that had no issues through my Apple TV. The actual TV is connected via WiFi, which I don’t use as the smart element because I have the Apple TV connected to it, flashed up “no internet connection”. I guess the TV polls every so often whilst not using its Android smart feature. Actual internet was up and stable, Netflix kept running and I could also browse the internet from my hard wired Mac. So the issue appears to be the Orbi. I’ll turn the Orbi off and use the router modems WiFi which is currently turned off and I suspect the problem will disappear. How do I fix a potentiometer lease running out issue ?
1topgazza
Also I don’t appear to have a orbilogin.net name and password. I usually manage things from the app
