jdk1120
Aug 06, 2021Apprentice
Intermittent wifi reboot issue
My Orbi router (RBR750 // RBKS753S) has been experiencing issues ever since I purchased it two months ago. The symptoms were very similar to DNS issues described in this previous thread (https://comm...
jdk1120
Aug 09, 2021Apprentice
Hi, to answer your questions:
- I have Verizon FIOS using the modem they provided (it is the standard black model, but do not know exact model name as it does not indicated and it is tightly affixed to my wall).
- The reboot issue happens every ~15 minutes when it's bad. When it's not bad, I've gone through a day without the issue.
- I use channel 11 for 2.4ghz as instructed by an Orbi technician's help over online chat
- I do not know what RBS is so that setting must be at default
- Yes, wifi neighbors, at least 5 nearby
Could you let me know whether this issue is common among other users and what is being done to resolve it? Thank you.
Aug 09, 2021Guru - Experienced User
Seeing one other here:
If you have done most troublesooting includeing factory resets and such. I'd ask NG support about an RMA.
- jdk1120Aug 19, 2021Apprentice
Hi guys, I just wanted to update you guys as I've been working with the support team to resolve this issue.
So far, nothing has worked; this is a persistent issue. This is quite unfortunate since this is not an issue before when I was using a much cheaper router. If anyone has found a workaround or solution, I'd much appreciate hearing your thoughts. I still have 1 more month of warranty left so I'll likely ask for a replacement.
- FURRYe38Aug 19, 2021Guru - Experienced User
