MDK74
Nov 18, 2022Aspirant
Intermittent wired connection from RBR750 router to my laptop. What's up?
I am hardwired to my Orbi (RBR750) router and get intermittent internet connection. It's hard to tell if the same problem occurs on the wifi. I think so. I've rebooted the modem and router multip...
- Nov 19, 2022
The Spectrum tech came this afternoon. H found a nick in the line outside. Fixed it.
So far, things seem to be working well. Pages are opening faster than they have in months. Hopefully, it'll stick.
Thanks all for your effort and suggestions.
MDK74
Nov 19, 2022Aspirant
Firmware: Orbi says it's current at V4.6.9.11_2.3.5
Same on satellites: V4.6.9.11
Modem/Gateway connection: Spectrum supplied modem. Not sure of the model #.
Wireless card on laptop: Intel Wi-Fi 6 AX201 160MHz
Wireless driver updated: Yes
Windows version: 11 Pro 22H2
FYI: Spectrum is coming out this afternoon to check their end of things. We'll see how that goes.
CrimpOn
Nov 19, 2022Guru - Experienced User
Do any other devices on the network exhibit the same behavior?
Does this happen "right in the middle" of using the laptop, or does it happen after waking the laptop, such as opening the cover or waking it from sleep mode?
