cdysthe
Nov 07, 2022Virtuoso
Internet and all connections goes out on my Orbi 850 system a couple of times a week.
Hi, Lately I have had the Orbi router drop connections at least twice a week. Wifi, Ethernet and the web interface is inaccessible. The LED is pulsing purple. I have to pull the plug and do a hard r...
Nov 07, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
cdysthe
Nov 08, 2022Virtuoso
Hi,
Firmware is 4.6.9.11. The modem is Netgear CM2000. I have not changed anything in months but this started happening all of a sudden. And yes, I have factory reset both router and satellite. I have done all the restarts in sequence as recommended. It still cuts all connections every three days or so or twice a week.
- FURRYe38Nov 08, 2022Guru - Experienced User
What is the CAT# LAN cable between the CM modem and RBR?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerIf you have done nothing to the Orbi system, may not be a Orbi issue persae...rather something at the ISP side maybe...
- cdystheNov 08, 2022Virtuoso
Can you first explain why I need to post information about the modem when the modem works just fine when I connect directly to it and also works when I hook my TP-Link backup router to it? I just do not get how the modem matters in this regard.
- FURRYe38Nov 09, 2022Guru - Experienced User
Can be anything, signal on the line is sub par or just enough degraded at a period of time that when the signal gets too bad, it causes the RBR to loose the connection with the modem and ISP services. There maybe bad cabling or bad connections that could be causing odd problems. So why we can you to post the CM modems status and event logs page. These have to be narrowed down as much as possible.
I have this same modem and have had my 8 series online with it before. The only items I saw when they were connected was on prior versons of FW, I saw these mysterious RBR reboots for unknown reasons. At that time I enabled email logging and that resolved the reboots. Since v.11 arrived I seen no more mysterious reboots after a factory reset and not enabling email logging.
