RBK3772
Jan 18, 2021Aspirant
Internet Connection
I have recently updated firmare (app suggested). My APP says INTERNET: Online but, on the app I cant test internet speed ( have signed terms / etc , it worked earlier) main issue is all devices i...
Jan 18, 2021Guru - Experienced User
What happens if you disable AX mode on 2.4Ghz?
- RBK3772Jan 19, 2021Aspirantfirmware is up to date. router is from large well know provider. they are isp and equipment maker. everything in the house works. i can try to disable 2.4 ghz. but it all worked earlier today for a brief time
- FURRYe38Jan 19, 2021Guru - Experienced User
ISP modem have a built in router by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- RBK3772Jan 19, 2021Aspirantwell. given that the ORBI worked great from June until i updated the firmware and the fact that it worked for a brie time today this really seems like overkill and perhaps another example of the main flaw with orbi that i read about before purchasing and see many others have issues with firmware. i am just wondering why 10 + other devices work without issue. the orbi set up day 1 was so easy. only one thing has changed. the firmware.
