RBK3772
Jan 18, 2021Aspirant
Internet Connection
I have recently updated firmare (app suggested). My APP says INTERNET: Online but, on the app I cant test internet speed ( have signed terms / etc , it worked earlier) main issue is all devices i...
RBK3772
Jan 19, 2021Aspirant
firmware is up to date. router is from large well know provider. they are isp and equipment maker. everything in the house works. i can try to disable 2.4 ghz. but it all worked earlier today for a brief time
Jan 19, 2021Guru - Experienced User
ISP modem have a built in router by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- RBK3772Jan 19, 2021Aspirantwell. given that the ORBI worked great from June until i updated the firmware and the fact that it worked for a brie time today this really seems like overkill and perhaps another example of the main flaw with orbi that i read about before purchasing and see many others have issues with firmware. i am just wondering why 10 + other devices work without issue. the orbi set up day 1 was so easy. only one thing has changed. the firmware.
- FURRYe38Jan 19, 2021Guru - Experienced User
And could be that your ISP modem has a built in router and your ISP could have done something af well. Reason for posting options for you to check with the modem first and adjust accordingly.
- RBK3772Jan 19, 2021Aspirantappreciate your comments very much. but if it looks like a duck. usually a duck. thank you. will explore
