mmcloney
Feb 12, 2022Follower
internet connection
I just hooked up the orbi in my house and its working for the 2.4 signal, but not the 5G signal. Also it is only working on some web sites and not other ones. It seems to be blocking the secure sit...
Feb 12, 2022Guru - Experienced User
Did you try a power OFF of the ISP modem and RBR after you configured the modems IP passthru for the RBR?
