mmcloney
Feb 12, 2022Follower
internet connection
I just hooked up the orbi in my house and its working for the 2.4 signal, but not the 5G signal. Also it is only working on some web sites and not other ones. It seems to be blocking the secure sit...
Feb 12, 2022Guru - Experienced User
How do you know the 5ghz isn't working?
The orbi uses bandsteering so devices are only going to see one SSID.
Are you using a wireless scanner to find out what's broadcasting and if so, what one is it?
