Rencortez
Jan 13, 2021Follower
Internet drop
First of all how the hell does orbi have a community for ORBI AX and ORBI AX6000 is not even on the drop down for models. First failure for NETGEAR wtf. Second. Not sure if anyone is having drop...
Jan 13, 2021Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
Try CTS values to 2347 under Advanced Tab/Advanced Settings/Wireless Settings
Wired connecte game consoles is preferred.
