kekkie
Sep 28, 2021Aspirant
Internet dropping on Orbi V4.6.3.16_2.0.51
Hi, I have an Orbi Router with Satellites. In the past sometimes internet dropped for a minute or two, it quickly resolved itself. I thought it was related to my ISP. But today internet connect...
kekkie
Thank you, it seems I'm f**cked then.
For me it always happens during an MS Teams call now, very frustrating.
It seems there is not much to do other than a factory reset...
Sep 28, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
I would not mark your post as solved until we identify the real problem.
- kekkieOct 18, 2021Aspirant
Hi FURRYe38 , I did not know this topic was marked as solved. I did not do this but maybe I clicked wrong somewhere.
Anyway. The problem is not solved. I've been working from the office mostly the last 2 weeks so problem was limited to my kids getting annoyed when playing Brawl Stars :-).
Anyway, over the weekend I have been struggling with this problem again myself - A LOT :-).
And then all of a sudden I seen an update available: V4.6.5.14_2.0.54
I thought "yes!" but the problem is not gone and even seems to be getting worse.
I also restarted both the router and the modem after the update.
Anyways, here is the model number of my modem. Provider is Telenet in Belgium.
-> 24*8 DOC 3 WIRELESS(DOCSIS)
My modem also contains a wireless network which is disabled. I'm going to enable that to "proove" that the problem is with Orbi: if Orbi says "no internet" and the wireless network on my modem still works, I hope this helps to get my money back if this does not get resolved.
I'm already pretty sure since a reboot of the Orbi resolves the problem.
Any other tips would be greatly appreciated!
- FURRYe38Oct 18, 2021Guru - Experienced User
If the modem has wifi built in, then this means the modem will have a router built in as well. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopI would try option#2 first, then Option #3...
FURRYe38 , thank you.
Your response helped!
But not the way you think. Just got of the phone with my ISP to check about the bridging, and appearanty my Modem is randomly restarting.
They are sending someone over to investigate the problem and probably replace the router.
Thank you anyway for your help.
