OzNetwork's avatar
OzNetwork
Follower
Jul 12, 2024
Internet drops and recovers (sensing a change in network) RBR750 MESH
hi I setup my network with my own network name rather than allowing to use the default ORBI85
it appears that wjile it allows me to use my own network name at some point ir connect with its own internal name
my browser drops and recovers (msg: sensing a change in network)  i have a RBR750 MESH any suggestion how to eliminate this problem other that using the router default name.
Thanks
Oz
  • FURRYe38's avatar
    What device are you connecting with?
    Is this device wired or wireless connected to the MESH system?
    What browser are you using?
    Does the front LED on the RBR turn PINK when this happens?
    Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
    How many RBS are deployed?
    What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
    Are the RBS wireless or ethernet connected?
    Does this happen with the RBS turned OFF?
    Does this happen with both wireless and wired devices?
    What channel configurations are currently set on the router?
    Be sure to disable any MAC Address randomizers on phones and pads while at home:
    https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
    Armor, Smart Parental Controls or Circle, Traffic Meter.
  • FURRYe38's avatar
    Any progress on this?
    Thanks
    Oz
