Dryath
Jun 05, 2021Aspirant
Internet drops both wired and wireless RBS850
So i bought this setup recently when i moved house with the router and 3 satellites and all its given me so far is headaches. Im on virgin media with the hub in modem mode directly plugged into the o...
Jun 06, 2021Guru - Experienced User
virgin hubs are notorious on here for not properly functioning in modem only mode.
If you put the virgin hub in router mode (disable its wifi) and then the orbi in access point mode, does it function properly?
- DryathJun 07, 2021AspirantSo i set the hub in router mode, disabled the wifi and changed the orbi to ap mode. Still getting around 40mbps when i should be getting 500+ and this is on my pc directly wired to the main orbi.
- FURRYe38Jun 07, 2021Guru - Experienced User
Check your connection rate on the PC to make sure the ethernet connection is 1000Mps.
You can do the same on the RBRs web page under Advanced Tab/Connection Status button and make sure it's connecting at 1000Mpbs to the ISP modem...
- DryathJun 07, 2021AspirantBoth are showing 1000mbps not sure whats up with it, before when it was set with hub on modem mode and orbi router id get 500+ that then dropped randomly to 40 now im stuck at 40 :(
