Dryath
Jun 05, 2021Aspirant
Internet drops both wired and wireless RBS850
So i bought this setup recently when i moved house with the router and 3 satellites and all its given me so far is headaches. Im on virgin media with the hub in modem mode directly plugged into the o...
Dryath
Jun 07, 2021Aspirant
So i set the hub in router mode, disabled the wifi and changed the orbi to ap mode. Still getting around 40mbps when i should be getting 500+ and this is on my pc directly wired to the main orbi.
Jun 07, 2021Guru - Experienced User
Check your connection rate on the PC to make sure the ethernet connection is 1000Mps.
You can do the same on the RBRs web page under Advanced Tab/Connection Status button and make sure it's connecting at 1000Mpbs to the ISP modem...
- DryathJun 07, 2021AspirantBoth are showing 1000mbps not sure whats up with it, before when it was set with hub on modem mode and orbi router id get 500+ that then dropped randomly to 40 now im stuck at 40 :(
- FURRYe38Jun 07, 2021Guru - Experienced User
And you are getting 500Mpbs when directly connected to the modem with the wired PC?
Swap LAN cables between the RBR and ISP modem with different. CAT6 is recommended.
Has a factory reset been performed on the RBR any?
