firenut34
Dec 07, 2022Aspirant
Internet gets dropped
I have the Orbi Rbr750 with one rbs750 satellite. I have frontier fios for which I upgraded to their 1gig plan. My house is two story 2700sqft house. Frontier replaced the ont outside so it is their n...
Dec 08, 2022Guru - Experienced User
Does the front LED turn PINK when this happens?
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Also enable SIP ALG as well. Under Advanced tab/WAN Setup
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️
- firenut34Dec 08, 2022AspirantI have frontier fios with the FRX523 Ont. It will at times turn pink and other times it won’t. I’m just updated to firmware V4.6.14.3_2.3.12 The satellite is about 30 feet on the second floor.
- FURRYe38Dec 08, 2022Guru - Experienced User
This ONT happen to have a built in router and wifi in the ONT?
I've seen some reports that may have this.
Is the RBR getting a public IP address ##.##.###.###on its Internet port or a 192.168.something address?
Can you take a picture of the front of the ONT and post it here please?
Has a power off for 1 minute then back ON with the ISP ONT and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.- firenut34Dec 08, 2022AspirantI know it takes place of the modem, but not a router. They would rent me a router and then rent me the eero6
- firenut34Dec 08, 2022AspirantShould I turn on the WAN aggregation?
Does the ONT support WAN LAG?
