TURBOGUARD
Sep 30, 2020Tutor
Internet is down again, AX6000
Did they just push a forced update or something again because about a week or so ago I can even watch YouTube anymore. My PlayStation that’s hard wired keeps asking for authentication every 15min caus...
Sep 30, 2020Guru - Experienced User
How do you mean proble solved. Another broken FW?
I'm using v16 and on a 1G ISP service. No problems here with speed.
If you upated FW, please factory reset the RBR and RBS and setup from scratch. I would not enable Armor.
typo, Problem solved...
