js5
May 17, 2021Aspirant
Internet Port Going Bad?
This is my first post. I bought the RBK853 in December and it really has worked great up until a few weeks ago. Recently the Internet Port has begun flapping (going up/and down) losing Internet...
May 24, 2021Guru - Experienced User
Any progress on this?
js5
May 24, 2021Aspirant
Unfortuantly no. I tried rolling back to older firmware version and no luck there either. Still having the same issues if I have the Internet Port directly plugged in. Internet Port flaps (going/up down) and throughput really is choking when it is working.
With another router in front, the Orbi in AP Mode, and using a non Internet port the Wifi works great where it can reach. Problem is Satellites won't sync.
- FURRYe38May 24, 2021Guru - Experienced User
I'd make contact with NG support regarding this...may have a faulty unit.
