Sempytender
Nov 08, 2021Guide
Internet Port IP Address not matching real Internet IP Address
Hello, I'm currently trying to solve a port forwarding issue with my Netgear Orbi (RBR750 is the reported model) and I've stumbled upon something weird: When I go into Internet Port settings, i...
- Nov 08, 2021
Your ISP appears to deploy CGN, Carrier Grade NAT (RFC6598: IANA-Reserved IPv4 Prefix for Shared Address Space) to overcome the shortage of public IPv4 addresses.
The NBN does only make up the transport layer, anything above is under the ISP responsibility.
Talk to your ISP, requesting a public routeable IPv4 address on your connection.
-Kurt
schumaku
Nov 08, 2021Guru - Experienced User
-Kurt
Sempytender
Nov 08, 2021Guide
Thanks so much for a speedy reply. I will check it out. Could this be the root of all my port forwarding issues as well?
- schumakuNov 08, 2021Guru - Experienced User
Yes, of course. We have no control about the port forwarding on the ISP' CGN routers.
PS. Great explanation of the "is-situation" of your connection - made it easy to anser!
- SempytenderNov 08, 2021Guide
As a concluding note: Yes, this was the issue. And for 6 months, I've thought about throwing out my (brand new) Orbi routers because I couldn't get port forwarding to work.
Thanks for the assistance - saved me quite a bit of money. Was able to opt out of the CGNAT by giving my valid reasons for needing a real IP address :)
- FURRYe38Nov 09, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 if you want to help with a double NAT condtion...
