Sameem
Dec 31, 2024Aspirant
Internet slow in second floor - RBS750
Hi Guys, Would appreciate some knowledge or help with my situation. I’m currently on a NBN1000/50 internet plan. I have my RBR750 Router with two RBS750 satellites upstairs. One in each corner o...
Dec 31, 2024Guru - Experienced User
Would need to know total sq footage of home in feet.
Actual distances between the RBR and RBS. 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
- SameemDec 31, 2024AspirantTotal square footage of the home including land is 2680 square feet. The distance between the router and satellite I would say is 30-35 feet 🙂
- FURRYe38Jan 02, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS should be enough...Might test with the other RBS turned OFF.
- SameemJan 02, 2025AspirantSorry just curious but How come? Wouldn’t that worsen it? Like there’s no harm with having both satellites right? Which satellite should I turn off? The one that’s connected to my PC or the other one in the other room?
