Sameem
Dec 31, 2024Aspirant
Internet slow in second floor - RBS750
Hi Guys, Would appreciate some knowledge or help with my situation. I’m currently on a NBN1000/50 internet plan. I have my RBR750 Router with two RBS750 satellites upstairs. One in each corner o...
Dec 31, 2024Guru - Experienced User
Would need to know total sq footage of home in feet.
Actual distances between the RBR and RBS. 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰
Sameem
Total square footage of the home including land is 2680 square feet. The distance between the router and satellite I would say is 30-35 feet 🙂
- FURRYe38Jan 02, 2025Guru - Experienced User
For that size of home, the RBR and just one RBS should be enough...Might test with the other RBS turned OFF.
- SameemJan 02, 2025AspirantSorry just curious but How come? Wouldn’t that worsen it? Like there’s no harm with having both satellites right? Which satellite should I turn off? The one that’s connected to my PC or the other one in the other room?
Having too much wifi signals in the home can cause too much wifi signal over lap between the RBR and RBS and lead to device connection problems and odd behaviors. There is a sweet spot for Orbi systems.
