wadjei9000
Jan 03, 2024Aspirant
Intranet IP address in internet setup
Having previously been up and running just fine, I've changed ISP and am now unable to get port forwarding to work. I think the issue is in the Orbi, not the ISP but I can't figure out what the pr...
- Jan 03, 2024
I presume you mean that IPv6 is disabled on the RBR router?
Ya seen some ISPs have odd issues with IPv6. Not to mention Orbi FW can have some oddities as well.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
wadjei9000
yeah, might well be a PPPoE thing.
I ended up finding an old settings backup (from the Sky days) restoring that and reconfiguring the internet login section and, voilĂ everything started working again, exactly as before!
Unfortunately, the backup cfg files are all binary so I will never know what it was that borked the router so hard. As far as I can tell, all the important screens look identical (apart from the IPv6 one).
Thanks for the tips everyone, I'll just make a mental note to take a settings backup before I go anywhere near the IPv6 screens again until Plusnet get their act together!
Jan 03, 2024Guru - Experienced User
Enjoy. 📡
