ALEUNG
Mar 28, 2021Aspirant
iOS device cannot load the webpage in correct layout
Last week I installed the RBK853 to replace my old Apple Airport extreme router. However, I found out that iOS cannot completely load the webpage in correctly layout. For example, the attached screen...
- Mar 31, 2021
You can try inputting same DNS addresses on the RBRs web page, save and apply. Do a full reboot on the ONT and RBR, set the iphone back to Auto for DNS and check to see if the problem continues...
Mar 29, 2021Guru - Experienced User
This the only web page that this happens?
Try a different device?
ebay loads fine for me on OSX 10.4.6 using Opera and iOS 14.4.1. I'm v12 FW.
- ALEUNGMar 29, 2021Aspirant
This happened to amazon, ebay and several webpages. They cannot display the html correctly and even sometimes say safari cannot find the server. Then I need to turn off/on wifi to try again.
I experienced it in my iPhone 11 Pro Max(iOS 14.4.2) and my iPad Air (iOS 14.4.2). These 2 mobile decices worked fine uner my old router Apple Airport extreme.
My notebooks are working fine under Orbi.
- FURRYe38Mar 29, 2021Guru - Experienced User
Poossible device issue if other devices are working thru Orbi.
I only know the ONT is Huawei provided by my ISP. Not sure the model number
