ALEUNG
Mar 28, 2021Aspirant
iOS device cannot load the webpage in correct layout
Last week I installed the RBK853 to replace my old Apple Airport extreme router. However, I found out that iOS cannot completely load the webpage in correctly layout. For example, the attached screen...
- Mar 31, 2021
You can try inputting same DNS addresses on the RBRs web page, save and apply. Do a full reboot on the ONT and RBR, set the iphone back to Auto for DNS and check to see if the problem continues...
ALEUNG
Mar 29, 2021Aspirant
This happened to amazon, ebay and several webpages. They cannot display the html correctly and even sometimes say safari cannot find the server. Then I need to turn off/on wifi to try again.
I experienced it in my iPhone 11 Pro Max(iOS 14.4.2) and my iPad Air (iOS 14.4.2). These 2 mobile decices worked fine uner my old router Apple Airport extreme.
My notebooks are working fine under Orbi.
Mar 29, 2021Guru - Experienced User
Poossible device issue if other devices are working thru Orbi.
- ALEUNGMar 29, 2021Aspirant
I only know the ONT is Huawei provided by my ISP. Not sure the model number
- FURRYe38Mar 29, 2021Guru - Experienced User
Hmmm. Ok
You can look at the RBRs Advanced Tab Home page and look under the Internet section and see if there is a ##.##.###.### address or a 192. or 172 or maybe a 10 IP address displayed there? If you see any of these 3 IPs listed, there maybe a router at the ONT.
Do you mean the following Internet port section?
