ALEUNG
Mar 28, 2021Aspirant
iOS device cannot load the webpage in correct layout
Last week I installed the RBK853 to replace my old Apple Airport extreme router. However, I found out that iOS cannot completely load the webpage in correctly layout. For example, the attached screen...
- Mar 31, 2021
You can try inputting same DNS addresses on the RBRs web page, save and apply. Do a full reboot on the ONT and RBR, set the iphone back to Auto for DNS and check to see if the problem continues...
ALEUNG
Mar 31, 2021Aspirant
It happens only in iPhone. So I only manually inputted 8.8.8.8 in iPhone/iPad Network setting. I didn't change anything in the RBR850 and other devices such as Notebook, Android tablet etc.......
Mar 31, 2021Guru - Experienced User
