AIRgauge
Jul 07, 2021Aspirant
iOS devices experiencing issues including switching to guest network and/or going offline
I recently purchased the Orbi RBK852 as an upgrade from the RBR50 but have experienced numerous issues. I returned one unit as tech support recommended that as an alternative to waiting three weeks f...
AIRgauge
What Firmware version is currently loaded? V3.2.18.1_1.4.14
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Cisco DPC3848V - it's a modem and router in bridge mode and is the same one I used with the RBR50. We have no choice in the make or model.
You should review the mac book networking settings and remove any Guest Network profiles that maybe there. THis is a Apple issue not a Orbi issue. WiFi devices pick and choose where they connect. I know mine does and my mac book only connects to the main SSID. I have recently enabled Guest Network and have not seen this with mine.
I recognize that this sounds like an Apple issue. We also have two internet radios that are dropping from the wifi, each from a different manufacturer. My husband's PC is running slowly and dropping from the wifi as well.
My phone is showing a message in the wifi settings that says the network is blocking encrypted DNS traffic.
What is the size of your home? Sq Ft? 3200 square feet
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
They are 30 feet apart and placed on different floors of the house, with only the floor (no walls) separating them.
Be sure to check your CTS and RTS values. If they are at 64, please change both to 2347.
Have made this change - will monitor.
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
