millerre1959
Aug 27, 2022Star
IoT Network - Is it Worth the Trouble?
 I have a well-functioning network setup with PCs, laptops, smartphones, and numerous smart home devices (lights, doorbell, thermostat, Logitech Harmony Hub and remote, vacuums, Google Home devices, e...
- Aug 27, 2022You will be able to control your devices from your smartphone or from Google Assistant, since you will still be on the same LAN.
I have 60+ IoT devices in my network, on the same SSID as my other devices. I’m still not convinced of value to have those devices separated in own radio network. My setup works perfectly as it is now.
ekhalil
Aug 27, 2022Master
