cdcutlip
Nov 19, 2024Aspirant
IP Address Conflict
I'm not very networking savy so help me out.
I am using Orbi Wifi 6 (RBK853). For some reason, my work laptop is getting assigned an IP address that conflicts with a SQL server database that I access through work. I access through work VPN but then can't access the SQL server database in question.
This happened previously and I was able to work around. I used the orbi app to identify the device that was getting assigned that IP address, disconnected the device, then was able to move forward. Now that it's assigning the IP address to my work laptop, I'm unable to apply this workaround.
I tried ipconfig/release and /renew, hoping the laptop would get a new IP address. I rebooted my orbi router. I rebooted my modem. Nothing works.
When I log into the netgar web interface, I see some sections that sound like they might help, but I'm too inexperienced to guess.
Under Setup - LAN Setup, under "use router as DHCP server" I see starting address and ending address. It starts with a 2 and ends with 254. Are these the IP addresses that are assigned to devices on the network? Could I start with 1 number higher than my problem IP instead of 2?
In this same section, I also see Address Reservation. What is this?
Ideally I would prevent any device from using this 1 IP address. Alternatively, could I force my work laptop to get a different, IP address?
I'm really confused. I'm pretty intelligent, but don't know this stuff. It seems odd to me that my work is using a 192.168 IP address for a SQL server database. I thought most of the 192.168 addresses were default for a lot of typical home wifi systems.
Can anyone help?
What happens if you change the default DHCP IP address pool range on the RBR to something like .100 to .200?
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-routerWhat is the 192.168.# on the VPN? 192.168.1.x? If so, try setting the RBRs router IP address from 192.168.1.1 to 192.168.0.1 and range .100 to .200 and test.
What FW version is loaded on the system?
Check with the VPN provider to get more information on what your system should be set to to help avoid conflicts.- cdcutlipAspirant
Thanks for the reply. All of this is a bit over my head. See my responses below.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-routerIs this what the "Use router as DHCP server" along with "starting address and ending address" is? Currently, it starts at 2 and ends at 254. My "problem" IP address is 35. This is where I was thinking if I set this to starts at 36 and ends at 254 it may solve my problem. Is that what you're suggesting above? Seems like it. I just don't want to screw something up and find myself without internet/wifi, especially since I don't know what I'm doing.
Is this the LAN/TCPIP section? On my orbi router, it is 192.168.1.1. In this approach, you're saying to change to 192.168.0.1? That would mean devices would be assigned 192.168.0.2 - 192.168.0.254 if I'm understanding correctly, right? That seems like it would work too, and not reduce my total number of available IP addresses, compared to using the above approach. Again, I'm pretty unfamiliar with all of this.
What FW version is loaded on the system?V7.2.6.31_5.0.24. I checked for firmware updates and there were none.
Check with the VPN provider to get more information on what your system should be set to to help avoid conflicts.The VPN is my work VPN. I've got a ticket into IT support but they haven't been very helpful. After connecting to my work VPN, if I check my IP address through ipconfig, it shows as 192.168.1.35, which is the problem IP that is assigned to the SQL server.
Yes, setting the pool range at .100 to .200 will help with your one IP address that you seen to get at .35 will avoid that. Any connected device would get nothing else besides something between .100 and .200.
Yes. Under Advanced tab/Setup/LAN setup. Make the change here then select the apply button and the system will reboot.
Ok.
Hopefully they can be of help as well. Ya, I'd change the RBRs LAN IP address to 192.168.0.1 and range .100 to .200, then this should solve the conflict coming from the VPN since they are usnig 192.168.1.1
