BulletRouge
Dec 19, 2020Aspirant
IP conflicts with RBR750
SO, my new AX4200 config (router & 2 nodes) is a mess. Before I set it up, I changed my existing setup to lease IP addresses < 130, and waited for everything to have an IP address in that range befor...
Dec 19, 2020Guru - Experienced User
So does the RBR and system work if you don't change the IP address range?
What range are you using? 192.168.1.2 thru .130?
I currently use 192.168.0.100 to .150 and don't see DHCP issues. Having ranges on either side of this default DHCP pool size leaves me room for static assigned devices. Everything with in the pool can be reserved IP assigned.
Be sure that when you set a new pool size, that you reboot ALL ther devices as well after the RBR configuration is applied. Be there are no static assigned IP addressed devices with in your new pool size.
BulletRouge wrote:SO, my new AX4200 config (router & 2 nodes) is a mess. Before I set it up, I changed my existing setup to lease IP addresses < 130, and waited for everything to have an IP address in that range before I did anything. Then I updated firmware all around, and did a factory reset before setting it up. Then before I let any devices connect to the Orbi network I changed DHCP to be > 130. then I let everything connect and virtually everything got new IP addresses. Then the problems began...
My wife yelled that our streaming device was pausing repeatedly. I checked the devie's IP address, and it was new. I rebooted the device for good measure. Same IP address. I went to the Netgear admin UI to look at the connected devices and it showed a completely different device on that IP address.
I was having the same issue on another streaming device, and same pattern. The IP address was showed as being assigned to a completely different device.
I have no other router or any kind on my network. I've had to swap back to my previous setup and everything is rock solid again...
Before I return it, any ideas??
- BulletRougeDec 19, 2020Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?So does the RBR and system work if you don't change the IP address range?
I am using Verizon FiOS, and I connect my router directly to that. Only one router on my network.
I did let the Orbi using the default range, but I had lots of conflicts. That's why I reverted back to my previous router, and setup non-conflicting IP ranges for them before trying again. I wanted to have confidence that Orbi wasn't assigning an IP address to a device that had not requested a new IP address yet.
- FURRYe38Dec 19, 2020Guru - Experienced User
Well when setting up any new router it's best to power OFF all devices while you get the new router setup. Then after the new router is set up, power one the devices one at a time and let them and router get IP assignments.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?- BulletRougeDec 19, 2020Aspirant
FURRYe38 wrote:Well when setting up any new router it's best to power OFF all devices while you get the new router setup. Then after the new router is set up, power one the devices one at a time and let them and router get IP assignments.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Never had to do that with any other router I've ever had. I have some 50-60 devices, some are hardwired and I can't really do that. When I did suspect a conflict, I would go around to that device and have it reconnect/reboot but that didn't help.
It is running the current version of the firmware, that was the first thing I did; upgrade to latest firmware, factory reset, then set up. I've done that twice now with the same results.
What I found amazing, ever after a device got a new IP address and I would see a completely different address in the connected device table, I couldn't actually find the MAC address in the table.
And I would swear that I would see different devices showing up with different addresses each time I looked; like I would see one set of devices in the top 5, then I would look again and there would be some that were different.
I'm sorry I don't really know the make/model of the ONT. It is provided by Verizon FiOS.
- Mikey94025Dec 19, 2020Hero
BulletRouge wrote:I did let the Orbi using the default range, but I had lots of conflicts. That's why I reverted back to my previous router, and setup non-conflicting IP ranges for them before trying again.
Another thing you can try is setup a completely different IP address range on the Orbi than your old router, e.g., 192.168.2.* for your new Orbi network whereas 192.168.1.* was your old router's IP address range. Then when you switchover to the Orbi, only devices that have requested a new IP address from the Orbi will work. Any with an old/invalid IP address from your old router will not be able to communicate and you will be forced to restart each device after changing routers (which is necessary).
