BulletRouge
Dec 19, 2020Aspirant
IP conflicts with RBR750
SO, my new AX4200 config (router & 2 nodes) is a mess. Before I set it up, I changed my existing setup to lease IP addresses < 130, and waited for everything to have an IP address in that range befor...
Mikey94025
Dec 19, 2020Hero
BulletRouge wrote:I went to the Netgear admin UI to look at the connected devices and it showed a completely different device on that IP address.
Also, the Orbi admin website is usually pretty accurate but I don't trust the app as much as the admin website. In this case, did you reset/reboot the conflicting device so it gets a fresh IP address? The problem seems that it was using an older address but should be able to get a new and non-conflicting one.
BulletRouge
I am only using the website.
