cbruiners
Mar 07, 2022Initiate
IP reservations for Synology NAS
I have an new RBR853 setup, all is going great (day 3), but I'm struggling with assigning a internal static IP to point to my Synology NAS box. I logged into the web portal of the Router -> Advan...
- Mar 07, 2022
cbruiners wrote:
Thanks Furrye38, I do mean a reservation on the Orbi, not assigning a static IP on the NAS box.
Are you saying that I should change the IP pool (which then limits the DHCP allocation) to 10.0.0.100 to .200 for static IP's set on devices but for IP reservation I can / should leave the IP pool range as is? Yes. And just try assigning 10.0.0.130 to the NAS (I'll check the current usage pool to make sure no other device is using that IP address).And lastly, is there a preference between IP reservation and setting a static IP on a device? I like the idea of doing at the router as its a centralised list for me to manage, rather than on the device and router, but happy to accept otherwise. For devices that don't need much router management, devices like NAS, cameras and printers, where you don't manage the network configuration on these devices alot, static is preferred. I use the static method on my NAS, printers and cameras. The IP address doesn't change and if I happen to put another router online, I can do same thing on different router and all my devices that use static reconnect with no user configurations needed. Devices always have same IP address which doesn't change and easy to remember.
Mar 07, 2022Guru - Experienced User
Be sure to understand:
Static IP addresses are set ON devices.
Reserved IP addresses are set ON the router/RBR
Make sure your device doesn't a static IP address set already on the NAS. Set it for Automatic.
For Reserved IP addresses set on the router, they need to be with in the default IP address pool >10.0.0.2 to 10.0.0.254
If you want to use a static IP address ON the NAS, then change the default IP address pool from>10.0.0.2 to 10.0.0.254 to
10.0.0.100 to 10.0.0.200
This is recommended so you have room on either side of the pool for static IP addressed devices like NAS, Cameras, printers and such that don't need much router management.
cbruiners
Are you saying that I should change the IP pool (which then limits the DHCP allocation) to 10.0.0.100 to .200 for static IP's set on devices but for IP reservation I can / should leave the IP pool range as is? And just try assigning 10.0.0.130 to the NAS (I'll check the current usage pool to make sure no other device is using that IP address).
