micks_address
May 24, 2023Aspirant
IP6 configuration - router versus whatismyip values
Hi folks, I've enabled IPv6 on my orbi and used 'auto config; on the router i can see the 'ipv6 address on the WAN' but when i go to whatismyipaddress.com the value displayed there is not the sam...
micks_address
ok some updates.
What i am trying to do is access my home assistant running on rasperry pi remotely. I have followed guides to set this up using duckdns and nginx and it works when i am on the same wifi as the rasperrypi. I can use the url from duckdns and it will load my home assistant. Once i switch to another network it doesnt work. I have port 8126 port forwarded on my orbi so requests to the router IP (which is cgnat) get forward to the home assistant.
I'm confident i can't use IP4 for this due to cgnat but ive seen i should be able to use ip6. So i enabled ipv6 with autoconfig and i can see a ip6 assigned to my router. I put this in duckdns ipv6 option but it still doesnt forward to home assistant.
Is what I'm doing possible? Is the router blocking the ip6 request from duckdns? does duckdns use ip4 and ip6 at same time? if it can't find ip4 will it use the ip6 etc?
Apologies if not making any sense.
Cheers,
Mick
- micks_addressMay 24, 2023Aspirant
ok so another update.. i added the ip6 address of my rasperry pi to duckdns and it works.. i can browse the home assistant using the duckdns url.. it only works from devices connected to my network though.. once i switch my phones wifi off and use lte the connection fails and times out
