CrazyEddie
Nov 06, 2021Apprentice
iPhone 11 Pro Max connects, then connection speed fails
I'm running an RBR850 and two RBS850s. Things have been great for a while. Yesterday I started experiencing problems with my iPhone 11 Pro Max staying connected to the primary network. It would be at 600+Mbps/40Mbps download/upload, then it would suddenly drop to maybe 1/40, or so low on the download side that I could not even run SpeedTest. The network was fine, as all of my other devices - including other iPhones and several Macs - worked fine. Eventually I figured out the Guest Network was an option (slower) to the iPhone 11, but (a) even the guest network only works for a brief period, (b) I don't understand what happened so suddenly (as I didn't do anything differently with the Orbi setup), and (c) why the guest is easier to stay connected - as they both have the same security setup.
I've already gone through all of the iPhone recommendations - including the sucky step of a complete factory reset. This morning I also went to the Apple store and they ran all of the hardware tests and confirmed all is OK. (And I was able to get WiFi, at least for the 30 minutes while I was at the store.)
Any suggestions?
So is Guest Network enabled on the Orbi?
Does all other devices work on the Orbi system?
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?How is the wifi settings configured on the RBR?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected.- CrazyEddieApprentice
FURRYe38 wrote:So is Guest Network enabled on the Orbi? Yes
Does all other devices work on the Orbi system? Yes
What Firmware version is currently loaded? V4.6.3.16
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I have my own cable modem - NG CM1150VHow is the wifi settings configured on the RBR? I'm not sure if these answers fully respond, but: 2.4G and 5G are enabled, and the channels are 11 and 48 (respectively); security is WPA2-PSK [AES]. Do you want to know the internet setup items as well?
Please note - I have not done anything to manually change the network settings in months.
What is the size of your home? Sq Ft? ~5k
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. The RBS is in the basement. RBS #1 is on the first/main floor, and RBS#2 is on the second floor.- FURRYe38Guru - Experienced User
"The RBS is in the basement." Do you mean RBR?
Basements are not great places for RBRs.
Are you sure the iphone is connected to a RBS or at the RBR?
IT's up to devices to pick and choose where they connect too...
