Pad-Rock
Oct 05, 2022Aspirant
iPhone 12 Pro and iPad Pro move around the house and jump between satellites
I have broadly the same issue as the one described. I have the RBR750 Router plus two satellites - the firmware versions V4.6.9.11(router) & V4.6.5.14 (satellites), although I've had the issue for q...
Pad-Rock
I have broadly the same issue as the one described. I have the RBR750 Router plus two satellites - the firmware versions V4.6.9.11(router) & V4.6.5.14 (satellites), although I've had the issue for quite a while and through multiple firmware updates.
Same as the OP, whenever my iPhone 12 Pro and iPad Pro move around the house and jump between satellites / router they looses connection whilst still showing up as being connected to the Wi-Fi in the devices' settings. My way to get them to work again is to toggle 'Private Wi-Fi Address' on and off to force them to reconnect. They will eventually reconnect if left for long enough, but it's not exactly seamless. I've tried having 'Limit IP address Tracking' both on and off on the devices, but that doesn't seem to make any difference.
I've done a bit of Googling and searching through the settings, but can't quite work out what is going wrong Hoping someone might be able to help and point out a simple setting I've missed!
- FURRYe38Oct 05, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡It's recommended that while your at home to keep Wifi Private IP Address disabled as it's not needed while your at home on a home network: https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-message
Also the RBS should be on same version of FW as what the RBR has loaded. You might loose connection with the RBS and becomes problematic to get them updated.
