Rogelio1
Jul 10, 2022Apprentice
iPhone 12 Pro loses WiFi connection with RBR850
I’ve had the exact same problem for the last 1.5 years and NOTHING has solved this. iPhone 12 Pro — I’ve done everything mentioned above — static IP address, factory reset Orbi, CTS changes, dropped ...
Sep 23, 2022Guru - Experienced User
Keep working with NG on this. Hopefully they can figure out what's going on.
satelly
Sep 24, 2022Aspirant
By resetting, what I did was firstly unplug the satellite from the powerpoint, then logged into the router using the Web GUI. Next to the satellite, it should show disconnected and then I clicked "Remove". I then connected the satellite via ethernet cable and used a paperclip and pushed on the reset hole at the back of the satellite as I turned on the powerpoint. There is a light next to the reset button which flashes red and then yellow. The bottom of the satellite flashes white. I pressed the sync button on the satellite and went to the router and pressed the sync button there. All this is done with the satellite connected via ethernet.
Hope that explains what worked for me.
