MPWestergaard
Jan 03, 2025Aspirant
iPhone and other devices will not connect to Orbi 960 Mesh
My Orbi 960 Mesh 3 pack is very soon going to be changed to another brand. I have tried anything also with support. The problem is that the Orbi system will not let the devices connect. Sometimes e.g...
Jan 04, 2025Guru - Experienced User
1. What modem/gateway is the router connected to?
2. what firmware are you on?
3. are you using any of the parental controls, access controls features?
4. Is this a new purchase? Or did this just start happening? (might try downgrading the firmware if so)
- MPWestergaardJan 04, 2025Aspirant1: Router is connected to a fiber connection. The box is Genexis.
2: V7.2.6.31
3: No
4: I have had it for a few years. The problem have been there all the time. And it have been expensive as mobiles goes on 5G all the time.- FURRYe38Jan 04, 2025Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?RBS wireless or wire connected to RBR?
What is the size of your home? Sq Ft?What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰Does this happen with the RBS turned OFF?
Does this happen with both wireless and wired devices?
What channel configurations are currently set on the router?Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Orbi-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220016/jump-to/first-unread-messageTry disabling the following and see:
Armor, IPv6 Smart Parental Controls, and Traffic Meter.You may need to downgrade FW as well. v.31 has issues posters have been posting about. I have my 960 system online currently on v.21 and working great.
