Gisele
May 11, 2024Follower
iPhone stopped connecting to Orbi
Apple phone yesterday has stopped connecting to our Orbi. No changes were made so we are baffled as to what has happened. We have the RBR750 in the living room and a satellite one in our bedroom. Ev...
CrimpOn
May 11, 2024Guru - Experienced User
This may be a result of two factors:
- The iPhone setting to "randomize MAC address when on WiFi" becoming enabled.
- Access Control on the Orbi system being enabled
Both Apple and Android smartphones have introduced a security feature designed to keep their phones from being "tracked" when they visit different WiFi locations (coffee shops, airports, etc.) and thus leaving a record of their physical location at specific times. See, for example:
https://support.apple.com/guide/security/wi-fi-privacy-secb9cb3140c/web
Even if users deliberately turn the feature off, when phone software is updated, the update often turns the feature back on.
If this happens, then the iPhone presents a rake MAC address to each WiFi system, and the Orbi believes it is a new device.
If the Access Control setting has become enabled, either deliberately or by accident, then the connection will be refused.
See page 40 of the RBR750 User Guide:
http://www.downloads.netgear.com/files/GDC/RBK752/RBK752_UM_EN.pdf
If you could please check these setting, it would help determine if this might be the cause of the problem.
- donawaltMay 12, 2024Mentor - Experienced User
If that doesn't show any results.....
In Settings/WiFi I assume the network with your SSID does NOT show as connected?
Does it show in the list of WiFi networks to connect to? If so, what happens if you tap on it?
If it does show as connected - under Settings/WiFi, what happens if you toggle OFF Wifi at the top, wait 60 seconds, and toggle it on again? Does your network appear and get connected?
