phdeoliveira
Nov 19, 2024Aspirant
iPhone VPN Client won't connect to RBR750P VPN.
I'm been trying to get the VPN setup in my RBR750P Orbi Tri-band Mesh WiFi 6 Router. I setup Dynamic DNS. I couldn't get the service provider to be the NETGEAR option, but I was able to set it up...
CrimpOn
Nov 19, 2024Guru - Experienced User
Is the iPhone disconnected from the WiFi network when this test is performed?
VPN access depends on the user router being directly connected to the internet (not 'behind' another router).
When you use a web browser to access one of those "What is my IP?" web sites**, does it report the same IP address as is shown on the Orbi web interface, Advanced Tab under the Internet Port?
** such as https://whatismyipaddress.com/ , https://www.whatismyip.com/
phdeoliveira
Nov 20, 2024Aspirant
- I was in another network entirely (at work), plus I also did try just using LTE, being disconnected from my home WiFi.
- Yes, a different IP.
- CrimpOnNov 20, 2024Guru - Experienced User
This appears to indicate that the Orbi router is "behind" another router which is preventing the VPN connection from reaching the Orbi. (Often called a "Double NAT". Use internet search to find ways to correct that situation. Netgear has an article on the topic: https://kb.netgear.com/30186/What-is-double-NAT-and-why-is-it-bad )
- phdeoliveiraNov 20, 2024Aspirant
Interesting..
My current setup is ISP > Motorola Modem > Orbi.
Does that indicate a Double NAT scenario?
- FURRYe38Nov 20, 2024Guru - Experienced User
There a model # of the Motorola modem so we can help check to see what features, if any, the modem may have?
