Amirlit
Dec 15, 2021Guide
Iphone wifi6 Support?
Hi There, so can I get the Iphone 13 max to connect to Wifi6 or 6e? I enabled Wifi6 only on the router, but I still cant see the SSID in my list of avaliable wifi networks. I only see the 5ghz. T...
raven_au
Dec 17, 2021Virtuoso
On the iPhone 13 you will get Wifi6 if you your router supports Wifi6.
You won't get Wifi6e, the iPhone 13 doesn't support it.
Amirlit
Dec 17, 2021Guide
That doesnt seem to align. I turned on Wifi 6 only on the router, but I dont see the SSID in the list on my Iphone 13 Max.
