Amirlit
Dec 15, 2021Guide
Iphone wifi6 Support?
Hi There, so can I get the Iphone 13 max to connect to Wifi6 or 6e? I enabled Wifi6 only on the router, but I still cant see the SSID in my list of avaliable wifi networks. I only see the 5ghz. T...
Dec 16, 2021Guru - Experienced User
What router do you have?
Amirlit
Dec 17, 2021Guide
I have the RBRE960
- CrimpOnDec 17, 2021Guru - Experienced User
There is a difference between WiFi6 and WiFi6E.
WiFi6 means 802.11ax, which all of the Netgear 'AX' Orbi's support. This is a new encoding in the 5G WiFi spectrum.
WiFi6E is a totally new in the 6G radio spectrum.
One tiny letter (E) makes all the difference. Perhaps it would be entertaining to do any internet search on WiFi6E
