donawalt
Apr 03, 2022Mentor - Experienced User
ipV6 disconnecting on Orbi RBR850
(NOT RBK53 model in drop down, why is RBR850 not there?) I have RBR850, firmware V4.6.7.13_2.1.9, and a CM1200 modem connected to Comcast's 1.2/40 service. All is working well, speeds, modem numb...
- Jul 07, 2022
OK, it's been two weeks, and my IPv6 has been working perfectly all that time, no more disconnects! I am going to mark this thread as solved, with the update of firmware to 4.6.8.5 being the thing that fixed it. If others are still having trouble I suggest starting a new thread, as there may be multiple issues. Thanks everyone for your help!
donawalt
Apr 28, 2022Mentor - Experienced User
I did the power reset on the modem and router yesterday afternoon, Last night I encountered a strange problem. On 2 different Windows 11 laptops, things got really slow. On my MacBook Pro there were no issues. I couldn't figure out the problem, but to get to the DuckDuckGo home page in Edge took about 30 seconds, usually it's instantaneous. Quicken took about 3-4 minutes to bring up the first screen! I ran speed test, it took about a minute to connect, but then speeds were perfect (~ 900Mbps down, 40 Mbps up - so a very fast ethernet). One of the Windows is Ethernet connected the other is WiFi.
So I tried -
Windows restart
Windows power cycle
Power cycle modem
Power cycle RBR850
Power cycle Switch
Clear all cache etc. in Edge
I probably did some other stuff I can't remember.
It was still very bad today, almost unusable. So I thought about the ipV6 issues, and I disabled ipV6 on the router only. Boom - lightning fast again! So there was some sort of serious issue going on here. I am done with ipV6 for awhile, luckily I can afford to - maybe it will work consistently by the time its truly needed.
cdysthe
Apr 28, 2022Virtuoso
donawalt wrote:I did the power reset on the modem and router yesterday afternoon, Last night I encountered a strange problem. On 2 different Windows 11 laptops, things got really slow. On my MacBook Pro there were no issues. I couldn't figure out the problem, but to get to the DuckDuckGo home page in Edge took about 30 seconds, usually it's instantaneous. Quicken took about 3-4 minutes to bring up the first screen! I ran speed test, it took about a minute to connect, but then speeds were perfect (~ 900Mbps down, 40 Mbps up - so a very fast ethernet). One of the Windows is Ethernet connected the other is WiFi.
So I tried -
Windows restart
Windows power cycle
Power cycle modem
Power cycle RBR850
Power cycle Switch
That is very interesting! After IPv6 is lost on my 752 I have to toggle IPv6 and use Auto Detect and then sett DHCP. The issue is that Auto Detect takes a very long time and the router web UI gets unresponsive for a long time. It sometime takes up to a minute before things go back to normal. Normal being either having a IPv6 address or 6to4 tunnel or having to power cycle everything.. There's clearly issues with IPv6 although I have not had slow network performance like you had.
- donawaltApr 28, 2022Mentor - Experienced User
That's the first time I saw that performance hit, and on multiple Windows laptops.
- RedBatman89May 27, 2022GuideSo then how many Orbi devices you think this affects?
- cdystheMay 28, 2022Virtuoso
The weekly IPv6 drop just happened. It's mostly happening on Saturday or Sunday. Must be when Comcast renews IP or something like that. Anyhow, I have shortened the procedure to get back up:
1. Disable IPv6
2. Auto Detect IPv6
3. Wait at least 5 minutes.
4. Set IPv6 back to DHCP and I get a new IP lasting another 5 - 7 days.
When will we have an update? This is not hard to reproduce and happens like clockwork!
