donawalt
Apr 03, 2022Hero - Experienced User
ipV6 disconnecting on Orbi RBR850
(NOT RBK53 model in drop down, why is RBR850 not there?) I have RBR850, firmware V4.6.7.13_2.1.9, and a CM1200 modem connected to Comcast's 1.2/40 service. All is working well, speeds, modem numb...
- Jul 07, 2022
OK, it's been two weeks, and my IPv6 has been working perfectly all that time, no more disconnects! I am going to mark this thread as solved, with the update of firmware to 4.6.8.5 being the thing that fixed it. If others are still having trouble I suggest starting a new thread, as there may be multiple issues. Thanks everyone for your help!
donawalt
Jun 30, 2022Hero - Experienced User
Mine is still working great. I made a couple posts that I have since deleted, I was mistakenly on another network. Sorry for any confusion that might’ve caused, everything is working great here!
donawalt
Jul 07, 2022Hero - Experienced User
- cdystheJul 07, 2022VirtuosoMy IPv6 goes out every 5 days or so. We are giving up and have ordered some Ubiquity gear and use that for now. I will check back every now and then to see if it's being fixed. The Orbi will be up but we turn all WiFi off.
