donawalt
Apr 03, 2022Hero - Experienced User
ipV6 disconnecting on Orbi RBR850
(NOT RBK53 model in drop down, why is RBR850 not there?) I have RBR850, firmware V4.6.7.13_2.1.9, and a CM1200 modem connected to Comcast's 1.2/40 service. All is working well, speeds, modem numb...
- Jul 07, 2022
OK, it's been two weeks, and my IPv6 has been working perfectly all that time, no more disconnects! I am going to mark this thread as solved, with the update of firmware to 4.6.8.5 being the thing that fixed it. If others are still having trouble I suggest starting a new thread, as there may be multiple issues. Thanks everyone for your help!
donawalt
Aug 01, 2022Hero - Experienced User
Firmware is V4.6.8.5_2.1.9. It worked for 15 days. Both the IPv6 test page and Orbi router page indicate no configuration:
- FURRYe38Aug 01, 2022Guru - Experienced User
Whats the system Uptime show on the RBRs debug page? Just curious. Router IP address/debug.htm
- donawaltAug 01, 2022Hero - Experienced User
I found it, disregard private message....it says
System Uptime: 0 days 08:27:51
So about 8 hours ago it restarted.Interesting, not sure why it did that. No evidence of power fail in the house and I did not do it.
Do you have email logging enabled or no?
