donawalt
May 28, 2022Mentor - Experienced User
IPv6 still broken
Well, this morning I turned IPv6 back on after having it off for around 2 weeks, as I was losing the connection even though all the settings looked fine on the RBR850 web page. I turned it on at 7:3...
May 28, 2022Guru - Experienced User
What modem/gateway do you have?
I've had ipv6 enabled on my RBK752 and RBKE963 systems without a drop.
(don't have an 8 series to play with).
What firmware version are you on?
donawalt
Modem is Netgear CM1200. Firmware version is V4.6.8.2_2.1.9. It was fine for at least a year. Like I said, a number off people with Netgear on Comcast are having issues. Problem is, nobody its fessing up to the problem...
