KMDonlon
Jan 17, 2022Virtuoso
IPv6 with Firmware Updates
Tried all versions floating around above v. 4.6.3.16 and my phone will not pull the IPv6 addresses and if it finally does, it is after several minutes. However never an issue with v. 4.6.3.16 and belo...
FarmerBob1
Jan 18, 2022Luminary
IPv6 was hit or miss until a FW update in the mid v3.x.x.x releases. After that one update perfect and stable. A while later when a change to the IPv6 setup page removed the incoming WAN address display from underneath the first line of text, as in the LAN area, there basically has been no IPv6.
- KMDonlonJan 18, 2022VirtuosoWell I would hope they certainly hope this is not an issue moving forward, I have remained on v. 4.6.3.16 to keep my "stable" IPv6
- FarmerBob1Jan 18, 2022Luminary
I moved back to v4.6.6.11, had IPv6 this morning and now it's gone. I may have to join you.
- FURRYe38Jan 19, 2022Guru - Experienced User
Does v14 exhibt the same IPv6 problem as well?
