ShawnC
Aug 17, 2023Apprentice
Is 6.3.7 10 the newest 960 firmware?
Is 6.3.7 10 the newest firmware for the 960 series? No matter what I do this firmware drops all recognition of wired devices. And Yes, I already tried that. Grr. The only way to get my wired de...
Aug 18, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What wired devices do you have connected?
How are they connected? To the back of the RBR or RBS?
Any LAN switches in the mix? Brand and model please.
How was the system FW updated? Manually or via Auto Update?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System
Your post history only shows you were using a Orbi Pro. Completely different from Orbi Home stuff. My 960 has been working great for me.
The only way to get my wired devices back is to downgrade to 6.3.75. And it seems I am far from the only one experiencing this.
My post history will show the frustrations I (and many others) have had with Orbi firmware. Why is it so difficult to deliver what you promise?
