ShawnC
Aug 17, 2023Apprentice
Is 6.3.7 10 the newest 960 firmware?
Is 6.3.7 10 the newest firmware for the 960 series? No matter what I do this firmware drops all recognition of wired devices. And Yes, I already tried that. Grr. The only way to get my wired de...
Oct 31, 2023Guru - Experienced User
How are the RBS ethernet connected?
What CAT# cable are you using? If the RBS are ethernet connected using there 2.5Gb ethernet ports, CAT6A STP is recommended. If there using the 1Gb LAN ports, then CAT6 UTP is recommended. There IS a difference between STP and UTP cabling.
ShawnC wrote:
Thank you.
Updated to it today and it also removes my wired devices. So frustrating.
For the record, there are no switches in this network, it’s flat. The wired devices are connected directly to the router and sats.
Im going to try the factory reset trick again tomorrow on the newest firmware.
ShawnC
Oct 31, 2023Apprentice
Thank you.
The wired devices are using new (well a few months old now) cat7 cables from monoprice. I have tried switching cables around to no avail, and I have tested these cables with my fluke lanmeter.
The router and sats are in the same exact spots as my previous Orbi Pro were in.
I did the factory reset trick today and now I can see some of the wired devices (yay!), I will troubleshoot some more tomorrow
One of the weirdest parts of this issue.. I can see one of my wire attached servers but not any VMs running on it. I could see those VMs fine with the older firmware. Has anyone else had an issue with virtual devices running on barebones ESXi?
Thanks again for the assistance.
