haysjp
Jan 27, 2023Star
Is anyone else having serious reliability problems since this update?
Is anyone else having serious reliability problems since this update? I have an active support ticket open with netgear, but we've almost exhausted every configuration option. My roaming devices di...
haysjp
Jan 27, 2023Star
I don't want to piggy back on your issue because I don't have Nest Cameras in the mix. However, I'm running the the same system and firmware, and it's been unreliable since I got it. The firmware update actually broke my wired backhaul and confused me for a while. Multiple system reboots ended up getting me back to where I thought I wanted to be, but the reliability is just not there on this system. I have an active ticket open with Netgear Support, but we've exhausted almost every configuration option available.
My roaming devices lose wifi regularly and can't reconnect, my fixed devices that used to work fine lose their connections, etc.
I'm going to open a similar community post to see if anyone has additional ideas after more observation this weekend.
I can fallback to different solutions and everything works fine. It's just the Orbis struggling sadly.
Good Luck!
Jan 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Is Armor, SPC, IoT and Separate 6Ghz SSID networks enabled?
How are the RBS connected to the RBR, directly behind the RBR or is there a LAN switch in between? Brand and model of this switch please. Using the 2.5Gb LAN Ports or 1Gb LAN ports for wired backhaul?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- haysjpJan 27, 2023StarIt looks like comments from other threads were aggregated here so context was lost. I was planning on opening a new thread with the summary and a better title.
Are you a netgear employee? If so, I have a small novel with all of this information going in the support ticket and would point you there. If not, I'll summarize here again for more community visibility.
Thank you for what you do. I've read most of the product documentation and the relevant community content already. Running out of ideas, so fresh perspective welcomed!- FURRYe38Jan 28, 2023Guru - Experienced User
So if you can give us feedback to the questions presented, this will give us more of an idea of what you have and we can better help you in trouble shooting this. Not all users have the same configurations or environments which makes things different and not all users have the same problems as well.
If you read the information thats great, we still don't know what the specifics are and the questons presented will help direct us in our troubleshooting efforts. What this forum is for. Users helping users. My 9 series is working great for me.
Hope NG support can help you out then.
If not, then I would suggest that you return the system and find something else.
- haysjpJan 28, 2023Star
I'm happy to do provide all the data I have, configuration, trouble devices, etc.
My comment here is this is not a topic I created. I would actually appreciate it if my comments were put back on the original threads where they have context, and we start a new one with a different title. I said I was going to do this over the weekend, but somehow this got created on my behalf.
I'm not looking to waste anyone's time here. I'm observing the same behaviors several others are on this system. I'm glad your 9 series is working great and you in particular have been providing excellent support to the community. That is not the case for many others from numerous reviews and I'm willing to help try to isolate whatever scenario is causing that.
I bought the system from netgear.com and they are telling me it's past the 30-35 day refund window. I have time left on my 90 day support and the 1 year hardware warranty, but didn't want to escalate that just yet without giving this it's due diligence.
I'll be back with more detail ASAP. I don't like the way this topic was created with the lack of detail and context it has...
