Chrillthesill
Sep 21, 2022Aspirant
Is it possible to add 5 or more satellites (RBS850)with RBR850 router
Hi, Í´ve bought 5 satellites to my AX6000 router, but when Iam trying to connect the fifth satellite it turns magenta, and wont connect to the router. I know that Netgear says that the recommended nu...
- Sep 24, 2022
Glad thats all it was.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 21, 2022Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Make sure the RBS have same version of FW as the RBR. Try connecting the one RBS to the RBR via ethernet and see if it gets a IP address. If it does, use this IP address to make sure the FW is updated on the RBS web page. Turn OFF all other RBS while checking this one RBS.
- ChrillthesillSep 21, 2022Aspirant
My home is 190 m2, so that is 2045 sq feet. One plane and a basement. I have 2 satellites in the basement (one wired), one satellite in the garage (wired), one satellite in the masterbedroom (wired) and now I want one satellite in my kids room (wireless). I will try to connect the 5th satellite with the router using ethernet. Do you know if it is possible to connect a 5th satellite to Orbi wifi 6 (RBR850)?
- CrimpOnSep 21, 2022Guru - Experienced User
That Netgear knowledge-base article referenced above "recommends" up to four and clearly states that adding more "might negatively affect performance". I take that to mean, Yes, you can.
If the house is typical construction, that is a LOT of WiFi access points in a small area.
Yes I saw that reply on the Netgear site and interpreted it that way, but no one have told me how to do it. I know that it is a lot of access points, but I need one for my boiler, one for the garage etc. We have 190 m2 on the main floor and 80 m2 for the basement and 1200m2 garden.
- FURRYe38Sep 21, 2022Guru - Experienced User
So for that size of home you only need the RBR and 1 RBS. Having too much wifi signals with additional RBS will cause problems.
is the home of wood or concrete construction?
