Chrillthesill
Sep 21, 2022Aspirant
Is it possible to add 5 or more satellites (RBS850)with RBR850 router
Hi, Í´ve bought 5 satellites to my AX6000 router, but when Iam trying to connect the fifth satellite it turns magenta, and wont connect to the router. I know that Netgear says that the recommended nu...
- Sep 24, 2022
Glad thats all it was.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
CrimpOn
Sep 21, 2022Guru - Experienced User
Chrillthesill wrote:
when I am trying to connect the fifth satellite it turns magenta, and wont connect to the router. s.
Could you provide more detail about the connection attempt? (i.e. the exact steps taken. Using the Orbi 'app' or the Orbi web interface, etc.)
(My typical practice is to connect a new satellite in the same room as the router so that I can perform the process without running around the house. After verifying that the satellite connects, I then move it to the desired location.)
- ChrillthesillSep 21, 2022Aspirant
I use the Orbi app. I have tried to get close to the router with the satellite. I have turned all the other satellites off and also reset the satellite and used the sync button on both the satellite and the router. Nothing helps. Maybe an ethernet cable will do as proposed earlier. But I still dont know if it is possible to add a 5th satellite.
- CrimpOnSep 21, 2022Guru - Experienced User
I use the Orbi app.
Most of the users on the forum are more comfortable using the Orbi web interface. (I certainly am.)
Is there a computer (desktop, laptop) or tablet that can be used to log in to the web interface?
(Smartphone screens are too small to be used with the full screen web interface.)
As there is absolutely no documentation about "what's going on?" with the Orbi app, there could well be some limitation built into the app communication with the router that no one is aware of.
