Chrillthesill
Sep 21, 2022Aspirant
Is it possible to add 5 or more satellites (RBS850)with RBR850 router
Hi, Í´ve bought 5 satellites to my AX6000 router, but when Iam trying to connect the fifth satellite it turns magenta, and wont connect to the router. I know that Netgear says that the recommended nu...
- Sep 24, 2022
Glad thats all it was.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Sep 21, 2022Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System 📡
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
Make sure the RBS have same version of FW as the RBR. Try connecting the one RBS to the RBR via ethernet and see if it gets a IP address. If it does, use this IP address to make sure the FW is updated on the RBS web page. Turn OFF all other RBS while checking this one RBS.
Chrillthesill
My home is 190 m2, so that is 2045 sq feet. One plane and a basement. I have 2 satellites in the basement (one wired), one satellite in the garage (wired), one satellite in the masterbedroom (wired) and now I want one satellite in my kids room (wireless). I will try to connect the 5th satellite with the router using ethernet. Do you know if it is possible to connect a 5th satellite to Orbi wifi 6 (RBR850)?
- CrimpOnSep 21, 2022Guru - Experienced User
That Netgear knowledge-base article referenced above "recommends" up to four and clearly states that adding more "might negatively affect performance". I take that to mean, Yes, you can.
If the house is typical construction, that is a LOT of WiFi access points in a small area.
- ChrillthesillSep 21, 2022Aspirant
Yes I saw that reply on the Netgear site and interpreted it that way, but no one have told me how to do it. I know that it is a lot of access points, but I need one for my boiler, one for the garage etc. We have 190 m2 on the main floor and 80 m2 for the basement and 1200m2 garden.
- FURRYe38Sep 21, 2022Guru - Experienced User
What is the distances the garage from the main home building?
Whats this Boiler?
Part of a garden could be covered but the intent of the orbi system is for mostly internal building coverage with "some" external coverage on the outside.
So for that size of home you only need the RBR and 1 RBS. Having too much wifi signals with additional RBS will cause problems.
is the home of wood or concrete construction?
